changing iac valve and tps
whne changing the iac or tps do i need to dissconect the negative cable from the battery
my truck runs fine shifts fine through all the gears
it just dies whne im at a stop or when u go to shift in drive or reverse
Yes, you do. Computer needs to learn base values for the new parts.
+1, and anytime you are working with anything electrical it should be disconnected, regardless of whether or not you want to reset the pcm.
