brake pads have 4k and are cracking?
Old Dec 4, 2011 | 06:20 PM
biggreen2500's Avatar
biggreen2500
yeah no kidding lol 5K would suck bad... brakes once a month? lol
the last pads i had on my ram got be from 99k-148k
Old Dec 4, 2011 | 10:39 PM
Terribly's Avatar
Terribly
Originally Posted by gdstock
5k? Really? Something is wrong there. If I don't get 50,000 on a set of pads I would get p***ed! Get the best pads you can afford, and as Hey You mentioned, turn rotors if they need it (or replace). Yota has over 260,000 on it, and pads replaced four times in it's life. Wife's car had over 100,000 before I changed them, and they were factory original (which was a surprise for OEM).
I hope you meant 50k instead of 5k!
I think he does mean 50k
Wish my girl would go 100K miles before a brake job. I think her average is about 35k on her little Honda! (Scary to ride with!!!!!!!!!!!!!!!)
Old Dec 4, 2011 | 10:49 PM
gdstock's Avatar
gdstock
Do you feel like you need that extra brake pedal they put in driver's ed cars? lol
Old Dec 4, 2011 | 10:53 PM
Terribly's Avatar
Terribly
I fell that even that pedal with the OH S*** handle and all the bubble wrap in the world is not enough!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 5, 2011 | 12:49 AM
redheadhunter21's Avatar
redheadhunter21
Originally Posted by biggreen2500
i'm actually pretty easy on my brakes.... unlike most young people... andm y fronts are the ones cracking.. not rear not sure why you said repalce rear brakes...
once this pads are worn out i guess i'm just gonna order up some EBC green stuff and slotted rotors... cause they gotta be better than stock rotors...
If your rear brakes are not working right you will be stopping the truck with just the front brakes and making it work twice as hard and twice as hot, heating and cooling causes the cracking any part of the brake system that is not up to par will cause adverse effects on the rest.
Also another thing if you like splashing through puddles that can also cause your cracking
And yes I meant 5k on the pads, go through shoes in about 10k not worn out but enough that my parking brake has a hard time grabbing and the shoes are starting to crack.
I have 2500 calipers and wheel cylinders and I think my 5500 pound truck is a corvette, I put the breaking system through hell and most people that ride with me understand why I replace pads so often.
Brakes are one thing I pay attention to detail about, and would take my truck up against most vehicles its size, locking up the front tires and slideing to a stop can be done if needed and has saved me a few times.
My dad got 40k a set of pads when he drove the truck
Old Dec 5, 2011 | 01:07 AM
UnregisteredUser's Avatar
UnregisteredUser
Something's bad wrong there, man. Find it and fix it!
Old Dec 5, 2011 | 02:58 AM
biggreen2500
my brakes are working fine in the front and rear... i haven't looked at my rear brakes... maybe there cracked or idk... i'm just gonna swap the fronts for new ones and then once i get my taxes i'm gonna do slotted rotors on all corners and some top end EBC brake pads and see if tht helps thanks for the help... tho
Old Dec 5, 2011 | 06:21 AM
HammerZ71's Avatar
HammerZ71
I recently had a caliper seize up on the rear of my WJ. Took out the pads and rotor. The pads were red from heat and basically crumbling when I took them out. The other side looked good although the caliper was real rusty. Pads on that side had about 70% after being on 40k miles.
I went ahead and replaced both rear calipers, rotors and went with ceramic pads. Cost was right around $300 after tax ($305 to be exact). All parts were from Autozone and all have lifetime warranty...
Old Dec 5, 2011 | 10:39 PM
jswain's Avatar
jswain
Maybe your calipers are dragging or wheel bearings are bad, either one of those happening could get the brakes hot. My truck has nearly 175k miles, bought it new, and I've replaced the front pads once. Granted, I don't generally slam the brakes on or ride in the mud for entertainment purposes. I know you said you replaced the calipers, sometimes a rubber brake line can collapse after it gets old and hold a little pressure on the brakes even when brakes are not applied. Might want to jack it up and spin the wheels just to check, if you haven't already.
Old Dec 6, 2011 | 02:53 AM
biggreen2500
nothing hung up..i jacked it up and checked everything
