vibration in 4x4
Old Dec 4, 2011 | 12:22 AM
Terribly's Avatar
Terribly
I had to check out my driveshaft to make sure it didnt just have 2 Ujoints so I didnt sound stupid and have guys like you and HeyYou correct me. lol
Old Dec 4, 2011 | 09:51 AM
DoubleL24's Avatar
DoubleL24
I justed changed the front one that hooks into the front axle. I never took the double cardon ones apart. This would still cause it to vibrate?
Old Dec 4, 2011 | 09:52 AM
Recheck everything. If it didn't vibrate before, gotta be some manner of install problem.
Did you separate the front section of the driveshaft from the rear at the splines?
zman17's Avatar
zman17
Retired Moderator - RIP
Did you check it when you had the shaft out?
Old Dec 4, 2011 | 11:16 AM
DoubleL24's Avatar
DoubleL24
I didn't take driveshaft apart. I'm gonna pull it off and reinstall and see if that helps. Thanks guys
Old Dec 4, 2011 | 11:37 AM
zman17's Avatar
zman17
You don't have to take it apart to check them. Take it out like you are doing and check for play and/or binding. I suggest you take it to a driveshaft shop and let them rebuild the Cardan joint.
Old Dec 4, 2011 | 12:32 PM
DoubleL24's Avatar
DoubleL24
Ok I might do that, just don't know why it started vibrating. It never did before I pulled tranny and tc out to get my tranny rebuilt. I jus put new u joint on the front and the cardon joint seemed pre good no loose play or anything. So i didn't mess with that, I just bolted it back up.
Old Dec 4, 2011 | 12:42 PM
zman17's Avatar
zman17
Then just double check the install of the one you replaced. Make sure it is seated properly also. The are two small tabs on the yoke to help center the ujoint caps. Clean the rust off the yoke where the caps seat, and you'll see what I mean.
Old Dec 4, 2011 | 03:11 PM
DoubleL24's Avatar
DoubleL24
Ok ill try that. Thanks for the help.
