plug wires
Old Dec 4, 2011 | 11:30 AM
lastrights's Avatar
lastrights
Default plug wires
I'm due for a tune up , I currently have msd 8.5mm , will putting on factory wires make a diffrence ?
Old Dec 4, 2011 | 11:34 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Get a good set and you'll be fine. Wire them according to the TSB. I use Standard Motor Products brand and dont do the TSB and I've never had a prob.
Old Dec 4, 2011 | 12:30 PM
lastrights's Avatar
lastrights
all i needed to know thamks, i just dont feel like paying money for a brand again.
Old Dec 4, 2011 | 01:36 PM
kejobe's Avatar
kejobe
I'm using Summit Racing 8mm wires, no TSB routing, with no problems.
Old Dec 4, 2011 | 01:40 PM
drewactual's Avatar
drewactual
Originally Posted by kejobe
I'm using Summit Racing 8mm wires, no TSB routing, with no problems....... that I know of...
there.. .fixed that for you..
these trucks aren't real good at catching a misfire.. they usually need several consistent misfires to kick a code.. bad wires and/or routing won't always do it..
MSD 8.5's are about the best to be had LastRights, inspect them closely.. if there are no breaks, or wears, for the love of God, keep them..
Old Dec 4, 2011 | 01:43 PM
kejobe's Avatar
kejobe
They've been on for several months and about 5000 miles. with no problems....that I'm aware of. Better?
Old Dec 4, 2011 | 02:15 PM
zman17's Avatar
zman17
You are right, there needs to be a certain amount of mis fires detected, in a certain amount of time, before the pcm will throw a code. I use my Genisys scanner and can see any mis firing.
