Hard starting
Old Dec 6, 2011 | 07:57 PM
rbushmx's Avatar
rbushmx
Default Hard starting
I have been having issues with my 99 ram 1500 5.2. I have replaced the fuel filter/ regulator, IAC , PCV,and temp sensor. I did a leak test on the injectors and found 1 leaking and replace all the o-rings. I tested the fuel rail and when it is running it is about 50psi but when I turn the key off it drops quickly. All the fuel lines look good and I can't smell fuel any where. Any ideas will be greatly appreciated. Thanks
Old Dec 8, 2011 | 12:36 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I will move your post to the 2nd Gen Ram section.
Old Dec 8, 2011 | 12:30 PM
leahyhfarms's Avatar
leahyhfarms
I had simular trouble with my truck. I put in a new fuel pump and that stoped the fuel pressure leaking down fast. I think it should take about 20 min to loose the pressure.
Old Dec 8, 2011 | 01:40 PM
MedicNathan's Avatar
MedicNathan
Agreed. Same thing happened to me
