Hard Starting Issue
Old Dec 6, 2011 | 08:38 PM
rbushmx's Avatar
rbushmx
Default Hard Starting Issue
My 99 ram 1500 5.2 4x4 is having problems starting. The fuel pressure on the rail is about 50 psi when it is running but drops quickly as soon as i turn the key off. I did a leak test on the injectors and found 1 that was bad and I replaced the o-rings on the others. I have replaced the fuel filter/regulator, IAC,PCV,and temp sensor. Not sure what I'm missing but any ideas will be appreciated.
Old Dec 6, 2011 | 09:39 PM
gdstock's Avatar
gdstock
So did the fuel pressure stay up better after replacing the injector?
How are the plugs and wires? If you have good fuel pressure, you may be missing a good spark.
Old Dec 7, 2011 | 06:43 AM
rbushmx's Avatar
rbushmx
Fuel pressure stayed the same when engine is on but did not drop as fast when turned off. Plugs and wires are about a year old, but I will try a new set. Noid light didn't show any differences from injector to injector. Thanks for the helps
Old Dec 7, 2011 | 06:54 AM
rbushmx's Avatar
rbushmx
Anyone know what my fuel pressure should be with key on but not running.
Old Dec 7, 2011 | 09:56 AM
49 pounds or so, and it should hold it for a few minutes. (although, that is not absolutely critical.)
What starting problem are you having? Just long crank times? Or what?
Old Dec 7, 2011 | 08:19 PM
rbushmx's Avatar
rbushmx
Long crank or have to do key on key off a couple of times to make it start. I replaced the plugs, wire,and dist cap today and it didn't help but didn't hurt it either. Did another leak test on injectors and didn't see and fuel coming out any where. I think I should just get a new pump and see it helps.
