Steering play
Old Dec 6, 2011 | 11:31 PM
97tn4x4's Avatar
97tn4x4
Default Steering play
So ever since I lifted my truck my steering has been loose, like see sawing down the road. I finally got the money to upgrade to the 98 HD tie rods and steering has gotten quite a bit better but I have more play to the left than the right. Turning right it's very responsive but to left the steering wheel faces the 10 o'clock position or so before it actually turns. Any ideas on what I can do to fix this?
Old Dec 6, 2011 | 11:46 PM
gdstock's Avatar
gdstock
Check FSM. There is an adjusting screw on top of steering gearbox. Loosen locknut, and adjust accoring to FSM s.l.o.w.l.y.....
It is best to do it with the wheels off the ground and someone in the cab slowly turning the wheel after you make slight adjustments.
Make sure you retighten the locknut!
Old Dec 7, 2011 | 01:18 AM
97tn4x4's Avatar
97tn4x4
So more play to one side than the other is normal?
Old Dec 7, 2011 | 01:46 AM
biggreen2500's Avatar
biggreen2500
my 2500 with 35s does the same ****.. i'm about ready to take the truck and lite it on fire and let insurence deal with it
Old Dec 7, 2011 | 02:18 AM
97tn4x4's Avatar
97tn4x4
Its weird its like the truck was used on the nascar circuit turning left its whole life lol.
