No Throttle Responce ?
Old Dec 10, 2011 | 06:34 PM
Hylander7's Avatar
Hylander7
Default No Throttle Responce ?
When driving up a hill at about 65mph.
Driving along about 1/2 throttle and it starts loosing speed up hill,
"normal with any vehicle". So I start increasing throttle but there seems to be no responce from about 1/2 throttle to 3/4 throttle. No speed increase, no change in rpm's, no change in engine sound, "nothing".
Increase throttle to the point of down shift and it picks up speed.
Is this normal, no throttle responce from 1/2 - 3/4 throttle ?
Old Dec 10, 2011 | 06:40 PM
Check TPS first. Have you fixed the plenum? how old are the O2 sensors?
Being in overdrive, you are prolly running about 1700 or so RPM at 65? You should feel something when you start giving it more gas.... might also wanna consider checking the TV cable adjustment.
Old Dec 10, 2011 | 06:51 PM
UnregisteredUser's Avatar
UnregisteredUser
What HeyYou said, but keep in mind that overdrive is meant only for unladen cruising at highway speed on flat ground. Once you're into a hill, mash the button to get back into direct drive.
Old Dec 10, 2011 | 09:20 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Hylander7, we'll have to get together and do some side by side comparisons, yo!
Old Dec 10, 2011 | 10:25 PM
lastrights's Avatar
lastrights
If you drive 65 and und3r best to leave over drive off .
Old Dec 10, 2011 | 11:58 PM
Hylander7's Avatar
Hylander7
Have not yet fixed Plenum, will do after Christmas.
02 sensor looks original and two of the wires have a bare spot right where they go into the sensor. I'm running 1,800 at 65mph.
Not sure how to check the TPS or adjust the TV cable.
From 1/2 to 3/4 throttle I can feel a little when on flat ground, but nothing pulling a hill.
Old Dec 10, 2011 | 11:59 PM
Hylander7's Avatar
Hylander7
That would be Great
I have no other Ram to compair mine to, and this is the only Ram I have owned.
Old Dec 11, 2011 | 07:45 AM
Novarider's Avatar
Novarider
Why do you say that? I could see under 50 od off all the time but 65?
zman17's Avatar
zman17
Retired Moderator - RIP
The procedures are in a Haynes manual. And the appropriate free service manual download in the FAQ/DIY section.
Old Dec 11, 2011 | 11:50 AM
Hylander7's Avatar
Hylander7
Thanks
