moving looking for advice p1740
Old Dec 13, 2011 | 09:44 PM
SilverSS's Avatar
SilverSS
Also a 20' car hauler should weigh around 3000 to 3500 lbs empty.
Old Dec 14, 2011 | 08:03 AM
TwistedCage's Avatar
TwistedCage
well as that goes i must have been told wrong in the weight i was told 7000
Old Dec 14, 2011 | 08:08 AM
kejobe's Avatar
kejobe
Found this on trailershowroom.com it's a 7x20 tandem and is only 2000lbs. So that's 5000lbs less. Your getting closer to the max GCWR. I know that in some states you'll be arrested and lose your license and vehicle on the spot if you over weight.
  • Over All Length 26' 8"
  • Over All Width 8' 6"
  • Over All Height 8' 0"
  • Interior Length 23' 0"
  • Interior Width 6' 9"
  • Interior Height 5' 10"
  • Rear Door Width 6' 4"
  • Rear Door Height 5' 6"
  • Frame Material Aluminum
  • Tongue Weight 250 Pounds
  • GVRW 7,000 Pounds
  • Empty Weight 2,025 Pounds
  • Cargo Capacity 4,975 Pounds
  • Floor Height 18"
  • Hitch Height 13"
  • Ball Hitch Size 2"
Old Dec 14, 2011 | 11:52 AM
Augiedoggy's Avatar
Augiedoggy
isnt the 1740 just a pressure solenoid error? Why chance it... they are $50 online and it only takes 30 minutes to an hour to change it. You can even reuse the fluid if your tight on cash... It would suck to be stuck in limp home mode while towing. I would think the poor pressure flow could mess things up fast under that kind of strain
Old Dec 14, 2011 | 06:23 PM
zman17's Avatar
zman17
Retired Moderator - RIP
That's the Governor Solenoid and Gov pressure switch you are thinking of. He needs to replace the TCC and OD solenoid unit and hope for the best.
Old Dec 14, 2011 | 06:36 PM
Augiedoggy's Avatar
Augiedoggy
OK thats pretty easy to do too ...you can unplug them without replacing the wiring harness if its not damaged....I had mine out too.. (they are about $50 also... but rarely fail... mine threw a code because there was bits of metal from my failed torque converter plugging it up and plugging valve body passages.
Old Dec 15, 2011 | 06:55 AM
Novarider's Avatar
Novarider
1740 Means the torque converter isn't locking up. When the torque converter doesn't lock it causes the tyranny to overheat. You are going to cook the hell out of that tranny/fluid by towing that much weight for that distance without TC lockup.
