Hail Damage
Old Dec 14, 2011 | 01:25 AM
Coltybear's Avatar
Coltybear
Thumbs down Hail Damage
I had hail damage reeealy bad on my driver side of my pickup but replaced all the panels, door shells, but now all i need to do is the roof. I have a 2000 dodge ram 1500 slt. Do you know how I can go about this? I work at an autobody shop but the damage is to an extent that I dont think bondo/paint will work. Is there a panel or weld panel I can buy?
Old Dec 14, 2011 | 02:13 AM
J415's Avatar
J415
What about cutting a skin from a donor truck at the bone yard?
Old Dec 14, 2011 | 07:53 AM
Novarider's Avatar
Novarider
Why not pull the headliner and hammer out the dents from the inside?
Old Dec 14, 2011 | 09:18 AM
Wombat Ranger's Avatar
Wombat Ranger
Just cut it off and leave it that way. Never seen a drop-top Ram before!!!
Old Dec 14, 2011 | 09:33 AM
gdstock's Avatar
gdstock
+1 on pulling headliner OR get one of those paintless dent repair kits. Should be able to get most of them out that way. It will be slow, but I cannot image that putting on new panel would be either 1. easy, or 2. cheap. Old school way was on hot day, spray the dent with freon......
Old Dec 15, 2011 | 07:02 AM
Novarider's Avatar
Novarider
I have been told that laying a frozen towel on the dented area will pull dents out. Not sure if it works or not but it's a really cheap way to pull dents if it works.
Old Dec 15, 2011 | 09:33 PM
gdstock's Avatar
gdstock
I have done that as well as using ice cubes. Only problem is sheet metal has to be hot - like being in the hot west texas sun in the summertime.
Old Dec 15, 2011 | 10:25 PM
J415's Avatar
J415
I believe it's called Thermal Shock
Old Dec 15, 2011 | 10:38 PM
jodaddy's Avatar
jodaddy
A guy at my shop just told me about this just last night. You take a torch to the backside to heat up the paint so it wont crack and then put a piece of dry ice on the dent and it is supposed to pop it right out.
Old Dec 15, 2011 | 10:39 PM
gdstock's Avatar
gdstock
I would think about a heat gun......torch in my hand would make it blister in a heartbeat!
