closed loop misfire
Old Dec 15, 2011 | 10:56 PM
  #21
NyghtProwler's Avatar
NyghtProwler
so it's a misfire as in a rough idle? And tapping on the TB makes it go away? What does the rpm's look like when it happens? New IAC? Did you clean the seat of the throttle body when replacing? Could be it's not seating properly until you tap on it.
Old Dec 15, 2011 | 11:00 PM
  #22
SpecialistBoicourt's Avatar
SpecialistBoicourt
actual misfire. random cylinders. yes i removed and cleaned the entire TB when i replaced the MAP, TPS, & IAC. (tapping the throttle gas pedal or throttle arm) rpm's flunctuate, typical misfire condition.
Old Dec 15, 2011 | 11:05 PM
  #23
SpecialistBoicourt
u would hafta read the 2 previous pages to better understand whats going on. i've been bustin knuckles for 15yrs professionally and this 1 has me stumped because my MasterTech scan tool shows all the sensor reading within their normal limits. ive done a compression test, cylinder leak down test, fuel pressure test, injector leak down test...... u name it. the only thing i havent done yet is replace the intake gasket or reflashed the ecm with updated programming. i dont have the software for the update. pls read the prior pages.
Old Dec 15, 2011 | 11:11 PM
  #24
NyghtProwler
sorry...I have read since post #1........didn't see the throttle body cleaning part......good luck
Old Dec 15, 2011 | 11:17 PM
  #25
drewactual's Avatar
drewactual
You and aim4 need to talk.. he's had a similar mysterious issue.. I don't know of he figured it out or not..
Have you put a vacuum gauge on it?
Old Dec 15, 2011 | 11:19 PM
  #26
SpecialistBoicourt
didnt mention the cleaning part, because i found no issues or oil under it when i replaced the MAP, TPS, & IAC. the stealership had it for the coil & not even they could figure it out. manifold vacuum stays @ 15.4hg from open loop and into closed loop. im wondering if the ecm is the culprit? but how do u test an ecm other than tapping on it w/your fingure?
Old Dec 15, 2011 | 11:22 PM
  #27
SpecialistBoicourt
drewactual, how can i git ahold of aim4? im FNG here & dont know my "F"ing way round this site too well.
Old Dec 15, 2011 | 11:26 PM
  #28
drewactual's Avatar
drewactual
Do a search using Google for "dodgeforum.com aim4squirrels"... He'll show up... He knows his business..
Old Dec 15, 2011 | 11:29 PM
  #29
SpecialistBoicourt
u rock dood.
Old Dec 15, 2011 | 11:32 PM
  #30
drewactual's Avatar
drewactual
I'd borrow a coil... They do strange strange things before finally giving up the ghost.. I have a yellow one (accel), and it was the straw that broke the camels back.. I'll never purchase anything accel ever again.. it missed, out of the blue, and worked without flaw- until it missed again.. it would never do it when I was waiting for it, but would when I least expected it to...
Aim4 made a valuable discovery with that.. he runs a msd 6a box, and said it quieted down when he removed it.. then he realized the msd was hitting it 3 times harder than the stock ignition, and therefore it would just kinda amplify the problem..
I'd find a loaned coil, and see if it happens...
