Steering shaft lock upside down
Old Dec 17, 2011 | 11:16 AM
ProudDad's Avatar
ProudDad
Default Steering shaft lock upside down
Hello all,
Yesterday I had the steering column out of my 1997 RAM 1500 automatic, to install the "Rock Solid" steering bushing fix. When it came time to reinstall the column, I found the steering shaft lock to only work in upside down position. After some searching, I've found others report the same symptom, but, no suggestions on what went wrong or how to fix.
Any ideas?
Old Dec 17, 2011 | 11:30 AM
zman17's Avatar
zman17
Retired Moderator - RIP
It's normal, the steering wheel does not lock as accurately as other vehicles.
Old Dec 17, 2011 | 01:00 PM
ProudDad's Avatar
ProudDad
Not to be argumentative - but normal? When I took the column out, it was locked at the 12 o'clock position. Following the directions of the Rock Solid bushing, I released the lock to test the fit of the bushing and feel of steering. I then focused on the repair at hand, without concern for the shaft lock. Apparently that was a mistake. It didn't relock and now only locks at 6 o'clock position.
Looks like I'll be taking it apart today. :-/
Old Dec 17, 2011 | 03:15 PM
zman17's Avatar
zman17
I'm pretty sure you'd be the first person that owns a Ram that the wheel locks at 12 oclock position. (unless of course you rotate it) . Besides removing negative battery cable, the first thing you need to do is use a rope or wire to keep the wheel from turning at all.
Old Dec 17, 2011 | 04:29 PM
ProudDad's Avatar
ProudDad
LOL, after thoroughly wasting my time, I found you are right, it is "normal". Could have sworn it was right side up before having to unlock it to do testing. Shows how memory isn't very good for things that weren't initially considered important.
At least I know how the whole mechanism works now.
Thanks.
Old Dec 17, 2011 | 04:33 PM
zman17's Avatar
zman17
No problem . Git ur done! LOL
Old Sep 24, 2018 | 06:05 PM
vabackcountry's Avatar
vabackcountry
Question 1999 Dodge Durango 4x4 5.9L
I have the same issue with my Durango. After replacing the steering gearbox my steering locks 180. I removed the steering wheel and both switches and learn that the lock is a solid mechanical detent. And the steering wheel only goes on the shaft one way. However, I thought for sure the wheel locked at 12 0'clock.
To clarify, does the wheel suppose to lock at 12 o'clock? If so, is there an adjustment?
Old Aug 3, 2020 | 07:49 PM
Old truk's Avatar
Old truk
I replaced my steering column put another one in locks upside down I'm lost how to fix it besides taking the steering wheel off and turning it right side
Old Aug 3, 2020 | 07:56 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The lock doesn't engage until the wheel is turned 180 degrees
Old Sep 19, 2022 | 11:38 AM
Mr_Sprocket's Avatar
Mr_Sprocket
Default Thank you
Thanks.
so, 2 things, how did the upgrade work for you? I just did mine and, like you found my steering wheel upside down. I had to replace the whole column because plow drivers are not careful with the equipment and a "non servicable" part. I had to xfer the lock mechanism from one to the other and could not get those controls to lock like the others , right side up.
