Turbo??!
Old Dec 17, 2011 | 10:24 PM
EvanBoothe123's Avatar
EvanBoothe123
Default Turbo??!
Anyone ever heard of someone putting a turbo on a 5.2l, and if so some suggestions and where I could buy one?
Old Dec 17, 2011 | 10:41 PM
bekins01ram's Avatar
bekins01ram
Was throwing the idea around myself for a while, after an interesting episode of powerblock, where they installed a remote turbo from this company (squires turbo systems - ststurbo.com) on a toyota tacoma. After seeing their price tag though, I decided it'd be much easier/ cheaper to DIY the project. After much research, i found that if you can get ahold of a turbo off of turbo cummins, it can be used, with low boost pressures. There are many turbos available on craigslist and ebay, but definitely would suggest researching a whole lot, before just slapping one on. There were alot of turbo sites/ forums i found, that have indexes of knowledge. Look in the turbo mustang forums, as their set-ups are similar to what we would do. I'm sure there are dodge forum members that'll shoot the idea down, and tell us we are crazy for considering the option. But there's a couple turbo dakotas in this forum, I just cant remember their names.
Anyways, that ststurbo will give u an idea about what you're looking for, or you order their universal kit, and they'd provide you with what you need. If you do order from sts, update this thread, cause I'd like more info about their products/ quality/ ease of install and such, from someone first-hand doing it.
Old Dec 17, 2011 | 10:44 PM
EndIsNear's Avatar
EndIsNear
Ask Hahns. I think his name is Hahns5.2? Can't remember, but he has a turbo on his Dakota. Pretty BA pickup
Old Dec 18, 2011 | 08:48 AM
kejobe's Avatar
kejobe
Search: https://dodgeforum.com/forum/2nd-gen-ram-general-discussion-non-tech/309418-turbo-5-2-dyno.html
Old Dec 18, 2011 | 11:25 AM
Hahns5.2's Avatar
Hahns5.2
A cummins turbo will work (Holset HX35 or it's older generation, the H1C) on a 5.2 but they are on the small side. For a mild build, something with a 60mm compressor and a T4 turbine would be more appropriate. If you go with a Holset you will want the largest turbine housing for it, 21cm^2, they were found on 1st gens with an auto.
I put down 290hp and 375ft/lbs on 7PSI with a rich tune, I've since turned up the boost another lb and have cleaned up the tune, so it's probably over 300hp and nearly 400ft/lbs at the ground now.
You will need a way to tune it, SCT can do it with large injectors but it's pretty crude. I really prefer a standalone computer, making changes on a my laptop vs waiting for a tune in an email from someone who's never seen my truck, no thanks. The stock auto tranny probably wont like the extra power much.
Old Dec 18, 2011 | 11:36 AM
CPTAFW163's Avatar
CPTAFW163
This is on a 5.9, but it positively can be used. 4-10 PSI. The 4PSI numbers are very nice. And this is on a BONE STOCK setup.
http://www.bionicdodge.com/bionic/in...p?topic=9467.0
Old Dec 18, 2011 | 12:49 PM
Hahns5.2's Avatar
Hahns5.2
Goes to show you how much a big turbo flows, but you'll sacrifice some low end for all that power. I know of another guy with a Turbo 5.9 Dakota, at 7PSI he put down 310hp with a 68mm turbo. Mine and his numbers are most typical among boosted stock Magnums.
Old Dec 18, 2011 | 01:23 PM
EvanBoothe123
.... This turbo talk is not English to me guys.
Old Dec 18, 2011 | 02:10 PM
Hahns5.2's Avatar
Hahns5.2
Then you need to do a lot more reading before you even get close to attempting something like this.
Old Dec 18, 2011 | 02:45 PM
EvanBoothe123
And where may I do this reading at, lets say a good place to start learning turbos.
