Ball Joint rivets...HELP!
Old Dec 20, 2011 | 08:16 PM
Tparkin's Avatar
Tparkin
If the lower bolts aren't TIGHT, you will get some noise out of the front end.
It's a truck.... spacers don't change spring rate. They are stiff by design.
Understood, thanks. The reason I asked about the stiffness is that it was considerably more "forgiving" before the spacers...with the same shocks installed.
Old Dec 20, 2011 | 08:24 PM
stewie01's Avatar
stewie01
What brand spacer's did you buy?
Old Dec 20, 2011 | 08:25 PM
Tparkin's Avatar
Tparkin
Rough Country 2", top mounted above the spring isolater
