Truck Shaking rapidly
Old Dec 21, 2011 | 06:31 PM
Or rotate the tires, and see if your shake is any different.
Old Dec 21, 2011 | 06:40 PM
BackwoodsRam's Avatar
BackwoodsRam
+1 i had a nasty shake at speed that went away after i rotated my front tires to the back. turned out my tires needed to be rebalanced
Old Dec 21, 2011 | 06:46 PM
chadhager03's Avatar
chadhager03
I'm voting unbalanced driveshaft, I had the same problems, except it started at 75, and a balanced driveshaft solved it
Old Dec 21, 2011 | 06:59 PM
BigGreyBeast94's Avatar
BigGreyBeast94
I had a bad vibration and shaking at 55+, then my rear u joint on my drive shaft blew out and now I'm in the hunt for a new one. Luckily it wasnt the front or i would have catapulted.. Crummy part is the u joints are 5 months old, I replaced them when I put the new rear in
Old Dec 21, 2011 | 07:04 PM
What brand U-joints did you get? Did the joint fail? Or did some bolts come loose?
Old Dec 21, 2011 | 09:03 PM
KxRideRon125's Avatar
KxRideRon125
i guess ill start at taking a look at all my u joints in the front and the driveshaft then get the tires balanced and go from there
Old Dec 21, 2011 | 09:18 PM
kejobe's Avatar
kejobe
Check all joints and suspension for excessive play also.
Old Dec 21, 2011 | 09:30 PM
Wombat Ranger's Avatar
Wombat Ranger
Sounds to me like a couple of horney fat kids in the bed of the truck gettin' things done!
Old Dec 21, 2011 | 11:17 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Old Dec 22, 2011 | 12:10 AM
mccart's Avatar
mccart
My buddy just bought a 02 cummins and it foes this too. At about 70, don't know what it is
