2000 Ram 1500 Wiring stereo issues (URGENT)
Old Dec 21, 2011 | 09:24 PM
thegoof529's Avatar
thegoof529
Unhappy 2000 Ram 1500 Wiring stereo issues (URGENT)
My friend has a 1500 ram, he wired a new head unit, amp and door panel speakers and now the truck won't start! It doesn't even try. The lights come on in the cab though, but radio won't work and truck won't start! He is stranded with no way to get home! Please help quickly!
Old Dec 21, 2011 | 09:32 PM
kejobe's Avatar
kejobe
Did he short anything? Leave the key on? Interior light on? Need a little more info.
It could be as simple that if he did any of the previous the battery could just be dead.
Was the battery disconnected? Reconnected?
Any lights at all working? Other than the ones mentioned.
Old Dec 21, 2011 | 09:37 PM
thegoof529's Avatar
thegoof529
he stupidly had the battery connected during the install. If lights come on then the battery isn't dead. we have checked fusses. un-plugged (for about an hour) and re-plugged back in the battery.
Old Dec 21, 2011 | 09:39 PM
kejobe's Avatar
kejobe
Possible just a coincidence. Any power to the starter?
Old Dec 21, 2011 | 09:44 PM
thegoof529's Avatar
thegoof529
nope doesnt click
Old Dec 21, 2011 | 09:47 PM
kejobe's Avatar
kejobe
Because it doesn't click doesn't mean there is no power. Need to check with a volt meter or test light.
Old Dec 21, 2011 | 09:49 PM
thegoof529's Avatar
thegoof529
Got it working! He put it in neutral and tried and it fired right up!
Old Dec 21, 2011 | 09:51 PM
kejobe's Avatar
kejobe
Probably neutral safety switch is going bad or it wasn't fully in park then (operater error).
Old Dec 21, 2011 | 09:52 PM
thegoof529's Avatar
thegoof529
he put it in park a few times. just for some reason you have to have it in neutral to start it. May have screwed it up with they took part of the dash off. who knows! aslong as its working.
Old Dec 21, 2011 | 09:56 PM
kejobe's Avatar
kejobe
If there was wires run from the battery to the inside of cab, it's possible that the neutral safety switch got bumped and loosened the harness. I'd start there to find out why it won't start in park.
