Losing Fuel Pressure 01 1500
Old Dec 22, 2011 | 10:54 PM
tlbaker78's Avatar
tlbaker78
Default Losing Fuel Pressure 01 1500
Hello-
I have a 01 ram 1500 5.2. Its a great truck, but in the last 6 months it seems I am loosing fuel pressure or something. I say this because when cold or after sitting a while if I just turn the key and start it it cranks for a while, then sputters and starts. BUT i have figured out that if I turn the key on and off 3 times and let the pump build up pressure, it starts right up on first crank. It takes 3 times because when I turn the key n the pump only pumps so much each time.
NOW, I am not that auto savy so please dont attack my ignorance.
Does this sound like the pump, or hose leak, or injector or what? I would like to be able to just get in and start my truck. and next year I might sell it, (not sure yet, I hate to get rid of a great truck, just cant afford the gas). and if I sell it, I will loose out if I have to explain, OH y the way you have to key on and off several times to start it.
Any ideas? I do have another pump off a parts truck we have, same year and all.
Your help is greatly appreciated!
Tony
Old Dec 22, 2011 | 11:03 PM
bwdakrt's Avatar
bwdakrt
Definitely will have to replace the fuel pump to correct the problem. Check valve in the pump is bad.
Old Dec 22, 2011 | 11:24 PM
tlbaker78's Avatar
tlbaker78
cool thanks. I guess thats the next project. I will update and let everyone know the outcome
Old Dec 22, 2011 | 11:39 PM
bwdakrt's Avatar
bwdakrt
Just as a side note. Fuel pumps do go bad and wear out but their life can be extended by never letting the fuel level get below 1/4 tank. The fuel pump sits down in the gas and relies on the gas to keep it cool. When the fuel level get below 1/4 tank, the fuel pump is exposed, starts to heat up and over time will cause premature failure. Just a suggestion.
