Not starting after work done (electrical)
Old Dec 27, 2011 | 01:08 PM
  #21
sk187's Avatar
sk187
I have looked over everything today and tested every ground I could find visually, physically, and with a test light. I have found nothing wrong with any of the grounds or other connections I have seen.
Im down to just getting a new starter and trying that.
One side note: This terminal is supposed to be positive right? It runs to the alternator. I only ask because its a black cable and the terminal next to it is also positive.
Uploaded with ImageShack.us
Old Dec 27, 2011 | 01:19 PM
  #22
Gary-L's Avatar
Gary-L
Veteran: Navy
IIRC, you completely pulled the dash when you replaced the heater core. The problem is not with the starter. You didn't reassemble and reconnect everything properly when reinstalling the dash. That's where the problem lies.
Old Dec 27, 2011 | 01:32 PM
  #23
merc225hp's Avatar
merc225hp
Have you tried using a remote starter button, and how about trying to start it in neutral.
http://www.powerhouseproducts.com/ph...er-switch.html
Old Dec 27, 2011 | 01:46 PM
  #24
sk187's Avatar
sk187
The heater core was done over a year ago, maybe more. The problem happened when I did the plenum.
Old Dec 27, 2011 | 01:52 PM
  #25
sk187's Avatar
sk187
Neutral does the same as park, no go.
Remote starter does the same thing as turning the key.
Old Dec 27, 2011 | 01:54 PM
  #26
Gary-L's Avatar
Gary-L
Veteran: Navy
OK, I got the threads mixed up. You'll have to carefully retrace what you did before/during/after the plenum repair. Something is not reconnected properly.
Old Dec 27, 2011 | 02:01 PM
  #27
sk187's Avatar
sk187
I am at almost 12 hrs total retracing everything, I cant find a single thing wrong.
The only thing I can even guess at is that the replacement alternator is bad. Its the only thing that has changed on this truck and if it is drawing to much power or something that would cause the truck to die.
Im heading to the battery shop right now to see what they say.
Old Dec 27, 2011 | 02:49 PM
  #28
zman17's Avatar
zman17
Retired Moderator - RIP
Those two connections in the PDC don't look too good to me.
Old Dec 27, 2011 | 05:00 PM
  #29
sk187's Avatar
sk187
Very happy to report the truck is running again.
The starter tested fine at the battery shop and the guy gave me to new battery terminal ends to try out.
They worked apparently it was just the terminals the whole time. I have no idea why as my last ones seemed fine and worked when I drove the truck in the shop.
Now I am off to put it all back together thanks so much for everyone's help this place is amazing.
Old Dec 27, 2011 | 05:11 PM
  #30
zman17's Avatar
zman17
Congrats man. And thanks for letting us know the fix. I knew it was the connections all along. LOL
