fuel pump problem again
Old Dec 27, 2011 | 10:06 PM
ramhead101's Avatar
ramhead101
Default fuel pump problem again
hi i if you guys dont remember i posted a thread last week about my fuel pump but i was able to drop the tank and replace the whole sending unit with a bosch one. but now the truck runs a lil weird from a stop it hesitates a lil or sometimes it will like cough. what can be wrong? thank you
Old Dec 27, 2011 | 10:53 PM
gdstock's Avatar
gdstock
Did you disconnect battery while changing? Have you tried it since? PCM may need to be reset. Other things I would check is to verify fuel pressure, Check and/or clean IAC and check TPS. (Disconnect battery while doing any of these except checking fuep pressure).
And if you have not done so, you can download service manual in FAQ/DIY section. That will be helpful also.
