"Key trick"
Old Dec 29, 2011 | 04:17 PM
SweetTooth's Avatar
SweetTooth
Default "Key trick"
I just did that keytrick, since I don't have a scanner or anything. I'll have to to autozone.
Anyways, I did that key trick and my check engine light kept blinking.
Does that mean I have a code(s) ?
Old Dec 29, 2011 | 04:21 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Umm, it blinks because your are suppose to count them in a certain fashion. Sure would be nice to know what year your truck is. And if you are posting from a phone, ad the info to your profile, not just your sig.
Old Dec 29, 2011 | 04:28 PM
SweetTooth's Avatar
SweetTooth
Sorry, I was on my phone, so I couldn't get that much said.
I redid my signature.
I have a 97 dodge.
Which way am I supposed to count them?
Old Dec 29, 2011 | 04:31 PM
zman17's Avatar
zman17
The way this link says to. http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
Old Dec 29, 2011 | 04:36 PM
SweetTooth's Avatar
SweetTooth
12 Battery Disconnect Direct Battery input to PCM disconnected within last 50 ignition key-on cycles. Normal if battery has been disconnected, otherwise check battery power and ground connections.
I've disconnected the battery last week to clean terminals, that's about it.
Old Dec 29, 2011 | 04:39 PM
If that's the only code, then as far as the PCM is concerned, everything is hunky dory.
zman17's Avatar
zman17
You sir have no problem as far as the PCM is concerned.
