DIY Brake bleeder question
Old Dec 30, 2011 | 12:57 PM
J415's Avatar
J415
Default DIY Brake bleeder question
I'm getting ready to make my own brake bleeder.
Here's the link:
http://faculty.ccp.edu/faculty/dreed...eder/index.htm
http://www.bmw-m.net/TechProc/bleeder.htm
My question is, what's the max PSI that I can pump it up to? I'm guessing 25 psi?
Old Dec 30, 2011 | 01:19 PM
Neat idea. Pressure bleeders make the job a tad easier.... especially when there is only one of you. Don't think I would go much over 25 PSI on that though..... not sure what the plastic hose is rated for, but, I would be it ain't very high. Not to mention the seal at the cap/master interface. Don't wanna be blowing brake fluid everywhere.....
Old Dec 30, 2011 | 01:30 PM
crazzywolfie's Avatar
crazzywolfie
i just use a 2x4 if i have to do it by myself. pump brake, set 2x4 between seat and pedal and go bleed brakes. the seat usually applies enough pressure to get the job done
