motor mount problem
so now that my transmission is apparently taken care of. Now onto the rest of the "list". While doing my oil pump we noticed i needed to replace the driver side motor mount. No problem, usually, the upper hole closest to the firewall did not have a bolt in it and the hole is all kinds of "wallered" out. So i put the two remaining bolts into it and now there is a gap between the motor mount and the engine. What can be done? Can you put a heli coil in it? Can I find someone to weld a stud in the hole and then put it on the nut?
Can you post pics? Would make it easier to see the problem.
sorry, I haven't gotten a chance to take a picture but I figure it will probably be ok the way it is, BUT me being the way I am I think I will end up putting a heli coil in it. I'll let you know how it goes and try to remember to take a pic when I get the time...
