Power Steering Pump Question
Old Dec 31, 2011 | 06:08 PM
jdh0921's Avatar
jdh0921
Default Power Steering Pump Question
Quick question for you. When I received a new power steering pump it included 3 seals, and I was wondering what they were for. The reason I asked, is because when I removed the pump, I only had one seal on the pressure line. Is there more than one seal for the pressure line, or just the one? I also have a leak at the pressure fitting which is why I was wondering if there should be more than one seal on the pressure line.
Old Dec 31, 2011 | 06:38 PM
Which pressure fitting is leaking?
The pumps probably fit more than one application, so, you get more parts than you really need. Tossing a couple extra o-rings into a box, is cheaper than the box......
Old Dec 31, 2011 | 07:30 PM
jdh0921's Avatar
jdh0921
Its the line to the pump reservoir. I just wanted to make sure, I thought that might be what they did but they had the extras and I have the leak, since that would be an easier fix than removing the pump and reinstalling it.
Old Dec 31, 2011 | 07:46 PM
Are there o-rings on the ends of the lines?
Old Jan 2, 2012 | 02:06 PM
jdh0921's Avatar
jdh0921
Sorry, been out of town for the holidays (still am... )
But I should have said O-Ring instead of seal (I blame this on the eggnog, apologies ). The reservoir seal failed on the original pump. And there was only 1 o-ring at the tip of the pressure line when I removed the original pump. I was wondering if there should have been a 2nd o-ring in that line since it is leaking from there now.
Old Jan 2, 2012 | 03:29 PM
Check the o-ring, and see if it didn't get marfed up. Should only be one.
Old Jan 26, 2012 | 11:25 AM
jdh0921's Avatar
jdh0921
Old thread, but just wanted to follow up.
Pulled the O-Ring out of the pressure line of the power steering hose, and it was in fact shredded already. So I replaced it, initialized everything, and its running good. I might still have a tiny leak where the pressure line goes into the pump. Might be a defective pump, because the leak appears to be outside the connector. Might see if there's anything I can do that involves not taking it out again, but might not have a choice.
Thanks for all the help :-)
