kegger question
Old Jan 1, 2012 | 05:45 PM
nomind's Avatar
nomind
Default kegger question
I have a 97 1500 4x4 5.9 non egr engine but i have a 95 egr kegg can i just make a block off plate and run it on my truck after doing the mod?
Old Jan 1, 2012 | 06:22 PM
J415's Avatar
J415
yes...
Old Jan 1, 2012 | 07:22 PM
kejobe's Avatar
kejobe
Ditto.
Old Jan 1, 2012 | 09:10 PM
bwdakrt's Avatar
bwdakrt
Yes it will but be ready to do some serious cutting and removal of the center divider and EGR tube inside the intake. Can be done but takes time.
Also I believe you'll have a coolant temp sensor to plug off on the drivers side of the stat that is not used on your '97.
Old Jan 1, 2012 | 10:01 PM
J415's Avatar
J415
No. '97 was the last year were they put in a temp sensor and a temp sender. '98 they combined that into one unit, the same year they decided to get rid of the center divider on these keggers.
Old Jan 1, 2012 | 10:13 PM
bwdakrt's Avatar
bwdakrt
I stand corrected. Thanks!
Old Jan 1, 2012 | 10:42 PM
nomind's Avatar
nomind
Thanks I will keep you posted on the progress
