Dropping valve body
Old Dec 31, 2011 | 07:48 AM
97tn4x4's Avatar
97tn4x4
Default Dropping valve body
When I drop the valve body do I need a new gasket or will the old one be ok as long as it isn't torn?
Old Dec 31, 2011 | 09:48 AM
ABX2A's Avatar
ABX2A
Default valve body
Are you talking about the pan gasket or govenor body gasket?
Either way unless the pan gasket has been replaced with the factory reuseble one you will want to replace.
Good luck..
Old Dec 31, 2011 | 01:14 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I always tend to replace gaskets especially since their cost is relatively negligible. That is what I'd recommend.
Old Dec 31, 2011 | 04:23 PM
aim4squirrels's Avatar
aim4squirrels
VB gasket well be fine to reuse. Only 100 in/lbs. on the VB mounting bolts, and pay attention to where you pull them from as there are at least 3 different lengths.
Old Dec 31, 2011 | 09:56 PM
gdstock's Avatar
gdstock
Gasket on valve body?
Old Dec 31, 2011 | 10:05 PM
I thought it was just a metal separator plate?
Old Dec 31, 2011 | 10:13 PM
grupar14's Avatar
grupar14
I'am pretty sure it just a metal separator plate.
Old Dec 31, 2011 | 10:39 PM
gdstock's Avatar
gdstock
Metal separater plates (2) between the 3 pieces of body, and no gasket betwenn them or whare VB bolts to case. If I am wrong....I screwed up on mine and htere wasn't one there when I tore it down....
Old Jan 1, 2012 | 08:15 PM
97tn4x4's Avatar
97tn4x4
I took the governor body off and it had a gasket so I just assumed to vb would too. I've got to replace a tcc solenoid.
Old Jan 1, 2012 | 09:14 PM
gdstock's Avatar
gdstock
Yep. Gasket on governor body and TC and OD solenoids, but not for valve body itself.
