Transfer case vacuum indicator switch question
Old Jan 3, 2012 | 04:51 PM
99ram360sport's Avatar
99ram360sport
Default Transfer case vacuum indicator switch question
Hello,
I have a 1999 ram 4x4 with the 5.9L.
I noticed today that i have a green coloured vacuum line that is not connected to anything and appears to be broke of from somewhere. The vacuum line comes from the vacuum indicator switch on the transfer case. On the vacuum indicator switch there is red, black, white, and green vaccum lines. They then split and the white and green vacuum lines come up by the engine on the passenger side. Where the white line connects and the green line just hangs there.
Does anyone know where it is supposed to go?
Thanks for your help.
Old Jan 4, 2012 | 06:39 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The green line is just a vent. Does not connect to anything.
Old Jan 5, 2012 | 08:53 PM
99ram360sport
Ok thank you. I wasnt sure because the previous owner sealed the end of it off.
Old Jun 6, 2021 | 07:13 AM
William Clay Pitts's Avatar
William Clay Pitts
Default Transfer case vacuum indicator switch questionEdit Post
Transfer case vacuum indicator switch problem is on switch end the green line isnt connected an there are two more lines not either which goes where if you dont mind helpin me
Last edited by William Clay Pitts; Jun 6, 2021 at 07:18 AM. Reason: doesnt sound right
Old Jun 6, 2021 | 08:18 AM
Moparite's Avatar
Moparite
http://www.4x4wire.com/dodge/tech/solid_axle_cad/
