4x4 wire ?
Old Jan 6, 2012 | 09:16 AM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by Big_Purple_01
Well when i put it into 4hi it seems to be grinding and 4lo seems to be workign just fine i was just wondering what i should do it seems to be working in the drive way but i dont want to test it were it might get stuck. its just seems to be grinding what does that mean?
ok on that ... I would guess your transfer case is bad... if 4wheel low works but not high.... Just an fyi you arent supposed to use 4wd on dry pavement. (you seem new to the 4wd thing so just a heads up)
Also be sure the PO wasnt an idiot and changed the gearing in one axle but not the other to match.... It happens... that makes the front wheels turn at a different speed than the rear.... mismatched size tires will also do this and thats why you want to use all 4 tires of the same size on a 4wd. otherwise it puts a lot of strain and force on things wearing or breaking them.
