fan switch problem
Old Jan 6, 2012 | 11:40 AM
mcweaver's Avatar
mcweaver
Default fan switch problem
my fan in my truck only works on 3 (hi), it does nothing on 1 or 2. The AC blows cold and the heat also works. Im guessing it would be the fan switch in the dash, so I would just need to replace the switch? Does that sound right? I thought either the switch worked or it didn't? I wouldn't imagine it would be a relay or some sort?
Old Jan 6, 2012 | 12:13 PM
More likely to be the resistor block. Look around by the blower motor, should be a bunch of wires going to a plug, on a 'block' held in by two screws.
Old Jan 6, 2012 | 02:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
http://shop.advanceautoparts.com/web...RPSESWAMS_____
Old Jan 9, 2012 | 11:53 AM
mcweaver's Avatar
mcweaver
ok, ordered the resistor and it should be here Tuesday. Not sure when I'll get a chance to put it on, but I'll let you know what happens...thanks again for the help guys!
Old Jan 9, 2012 | 08:18 PM
formerkingoftheroad1999's Avatar
Do you heave to remove the blower to replace the resistor?
Old Jan 9, 2012 | 09:25 PM
Shouldn't have to. Should just be screwed into the heater box... two or three screws, and an electrical connector.
Old Jan 19, 2012 | 08:19 PM
mcweaver's Avatar
mcweaver
finally got a chance to replace to resistor and that took care of the problem. Thanks again guys!
