Cheap/Easy tuneups for 97 Ram
Boring? Have to check prices at machine shop in your area. Not the same everywhere. And it is a waste of money if you haven't checked plenum. And if timing set is original, then it is overdue. Check the things listed above. If plenum gasket is blown, add new cat to the list. These things will put some punch back in it. And when that is all done, look at 1.7 HS roller rockers and hemifever tune. I think you would be happy with all this done - - and saved a bunch of money as opposed to boring the engine. And as you tear down to bore, you will have to fix plenum and timing anyway!
Most shops see a 16 year old kid come in wanting is engine bored out for more power. They are likely going to take advantage and quote you more than someone who just needs a rebuild and seems like they are more experienced in knowledgeable of thier options...or they arent going to take you seriously because your a kid and figure your one of those dreamers with no clue.
This is one of those times when an older guy who can "Talk shop" and seems to know a bit can be helpful to bring along.
and rememberthe down sides, After spending all that money its still a 11+ year old truck and isnt likely to blow the doors of any Hemi out there...and when you want something new in a year dont expect to make your money back.
ps dont forget the tranny will need beefingup to hold up to the new motor.. hell I'd save for a tranny buildup anyway unless its just been done with the way your going to be pushing it...they arent too steller in these trucks
