Cheap/Easy tuneups for 97 Ram
What are some easy and cheap tuneups for a 97 dodge ram 1500. I have noticed a little lack in power lately and was wondering what I could do to maybe get a little back into it.
If it has high miles, check the compression or do a leak down test first before you start sinking money into it. Then you can do stage 1 with plugs wires oil change stuff, stage 2 by increasing the in & out air flow & even do some power adders, but make sure it is worth it first.
193XXX miles shes getting up there! I want it to run better over all but put some power back into it hopefully.
Trending Topics
Yeah, I second (third? fourth?) the compression test. If that comes out ok, need to do the basics first, including the plenum. While you are in that deep, timing chain and gears would most certainly help you out in the power department as well.
Given the mileage on the motor though..... it may not be a bad plan to just yank it, and either freshen it up, or replace it....
