Driver's side Front U joint
Old Jan 7, 2012 | 11:39 AM
atc250r's Avatar
atc250r
Default Driver's side Front U joint
So my left front wheel U joint is shot. Can I do it simply by removing the axle, replacing the joint, and sliding the axle back in, WITHOUT going into the diff at all? I guess I'm asking if my axle seal will get damaged during re-assembly. It doesn't leak at all right now.
Old Jan 7, 2012 | 11:42 AM
If you are careful, you can do it without trashing the seal.
Old Jan 7, 2012 | 01:41 PM
sam_priem's Avatar
sam_priem
i did both driver side and passenger side u joints on my truck a few months ago. i never went into the diff. and i have had no problems with leaks. just be a bit carefull.
Old Jan 7, 2012 | 02:17 PM
atc250r's Avatar
atc250r
Good to hear. Makes the job much easier. Will be doing it next week.
Old Jan 7, 2012 | 02:18 PM
kejobe's Avatar
kejobe
Same here. Then again 2 weeks ago to do balljoints.
Old Jan 8, 2012 | 06:28 PM
dhvaughan's Avatar
dhvaughan
treat the axle seal like glass when reinserting the axle.
the hardest part can be removal of the big axle nut 1-11/16 and the removal of the hub bearing from the knuckle.
here's some nice write ups.
http://www.pavementsucks.com/tech-article-5.htm
http://www.pavementsucks.com/tech-article-3.htm
precision brand makes some very heavy replacements.
