Valve spring ?
Old Jan 9, 2012 | 11:42 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Cool, you can get custom tunes without having to re-mortgage your house, and first born male child.
Still would look for a different cam.......
why does it have to be male child?
Old Jan 9, 2012 | 12:36 PM
mccart's Avatar
mccart
I think I found the right one, it is a comp cam.
http://www.jegs.com/i/Comp-Cams/249/...d=#moreDetails
With this one, stock valvetrain will work correct?
Old Jan 9, 2012 | 02:15 PM
merc225hp's Avatar
merc225hp
These are the valve train parts numbers I went with, good for .525 lift, I don't have the other info in front of me IE installed height, spring pressure and so on. When I get off my a** later today I will get you those numbers. I am sure there are other brands to choose from that might be cheaper.
Mopar part numbers
Magnum Valve Springs P/N P5249464
Magnum Valve Retainer P/N P4452032
Valve Keepers P4529218
Valve seals P5249661
Edit: The cam you have posted the lift is spec @ 1.5 ratio Cp / With long snout and 1.5:1 rockers. Stock springs cannnot be used.
Old Jan 9, 2012 | 02:45 PM
mccart's Avatar
mccart
The comp cam I posted is made for the magnum engines with 1.6 rockers. And the stock springs are good for .480 lift correct?
Mopar part numbers
Old Jan 9, 2012 | 02:50 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I would highly recommend you talk directly to Comp Cams.
Old Jan 9, 2012 | 02:58 PM
merc225hp's Avatar
merc225hp
Yes the stock spring are good for .480 lift but you don't want to run them maxed out.
Jeg's gave me little info on the cam, Summit has more info on it http://www.summitracing.com/parts/CCA-20-612-9/
I went to Comps web site and looked it up.
http://www.compcams.com/Company/CC/c...?csid=654&sb=0
