Tire Question And Clearance Issue
Old Jan 16, 2012 | 10:32 PM
DogeRamGuy1993's Avatar
DogeRamGuy1993
Default Tire Question And Clearance Issue
Okay so i have a couple things to ask.
1. Will i be able to clear 35's on my 01' ram 1500 , 5.9l ex. cab 4x4, 2.5" coil spring spacer and 1.5" block in the back?
2. This guy on Craigslist is selling 2 toyo open country's size 315/75/16 (aprox. 34.6) for $180 bucks mounted,balanced and 30 day warrenty, and they have 70% tread left. Is that a good deal? they are $250 a piece new, and i was just going to get 2 more and then ill have a nice set of 35's.
let me know guys, thanks
Old Jan 16, 2012 | 11:01 PM
mstephen89's Avatar
mstephen89
it will be close, probably be ok, if you don't articulate it to much, it may rub a little.
Old Jan 16, 2012 | 11:11 PM
DogeRamGuy1993
So ill be good then? i just dont want to buy them and then they dont fit
Old Jan 16, 2012 | 11:14 PM
mstephen89's Avatar
mstephen89
what backspacing are you running, that will have alot to do with it as well. If you are running stock wheels, that will help you some also
Old Jan 16, 2012 | 11:25 PM
DogeRamGuy1993
backspacing? and they will be going on another set of OEM dodge rims
Old Jan 16, 2012 | 11:29 PM
mstephen89's Avatar
mstephen89
oem dodge rims are 5" back spacing i believe, i would think that you will be alright, it will be tight, but do-able.
Old Jan 16, 2012 | 11:32 PM
DogeRamGuy1993
As long as its do able im okay with it, alot of people say i could clear easily , dont know who to trust, haha
Old Jan 17, 2012 | 12:45 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Being stock truck w/ only 2.5" spacers...will get you with major rub. It's doable after you've cut the inner fenderwell. Having the ORE stock lift, which is somewhere < 2" I had tire rub at the panel seam, which acts like a knife at about 20* turn. The 2.5" coil spacers I put on gave me about 1" clearance.
You will be doable with big time rub. Keep the wheels straight and you'll be just perfect.
