Balljoint Angle
Old Jan 20, 2012 | 11:16 AM
EndIsNear's Avatar
EndIsNear
Look at the balljoint angle in this picture. Its a 6.5" Fabtech Ultimate lift. The aftermarket control arm is supposed to correct balljoint angle. But this looks worse than mine. So could my angle still be okay compared to this? I just can't justify spending $600 on new control arms...
Old Jan 20, 2012 | 11:30 AM
redheadhunter21's Avatar
redheadhunter21
Originally Posted by EndIsNear
Wow I never would have thought of that. Have you done it to yours? But I haven't had an alignment done yet.
Yeah after adding the spindles it was just a tad off when aligning and the tires pointed a little in at the top so I took a Dremel type tool and made the slides about a inch longer and was able to align it without a problem.
Not quite sure what the difference on the 01 front end but it should be the same as far as that
