Where to get small parts?
Old Jan 21, 2012 | 10:56 PM
SarcasticDwarf's Avatar
SarcasticDwarf
Originally Posted by gdstock
Look in the Dodge parts manual located in the FAQ/DIY section. Most bolt specs are listed in the chart to the right with the part number. This will include diameter, length, and thread pitch. Most bolts are grade 5. Some are grade 8. There is a section in the Haynes manual that shows how various grade bolts are marked on bolt head.
Nifty, so in this case (p.39) it lists:
SCREW AND WASHER, Hex Flange Head, .312-18x.562
Why would it give part#06033043 when the dealer gives 6036671AA (that part number does not exist in the parts manual)?
Old Jan 21, 2012 | 11:39 PM
gdstock's Avatar
gdstock
Strange. I use the parts manual all the time, and usually print the page and take to dealer. Freaks them out. I won't tell them where I got it. Part numbers have always worked. main thing is to use the size given, and buy at hardwares store, Tractor Supply, or something like that Tractor Supply sells them by the pound...whether its bolts, nuts, washers, or a combination. I keep a selection of SAE and metric (metric not available at TS in Texas...) nuts and bolts and usually try to replace as I do repairs.
