Excessive Positive Camber
Old Jan 3, 2012 | 03:55 PM
CSCustomCars's Avatar
CSCustomCars
Default Excessive Positive Camber
Having a problem with my 2000 2500 4x4 diesel.
Just replaced the ball joints with Moog, non adjustable.
I was hoping the bad ball joints were causing the obnoxious ammount of positive camber, the front end is all solid and new now, but I still have a huge amount of positive camber.
I suppose since I just did the ball joints I can go back in there and replace the lowers or uppers with adjustable ones, but I'm hoping there's another way? Hub Spacers/shims?
I don't have exact alignment specs because frankly, I don't need to put in on a rack to see my tires on the top out farther than on the bottom, but I can take a picture or two for anyone if you'd like to see it.
Also, it's buring the outside edges of the tires in ~500-600 miles. Tires aren't cheap. Don't want to burn through them like this.
So, hub spacers? Or do i have to go spend another $400 on moog adjustable ball joints?
Thanks guys
Old Jan 3, 2012 | 04:10 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Positive camber? The prob is usually negative camber. I'd say there is a good possibility you have the wrong bj's installed.
Old Jan 3, 2012 | 04:12 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Is taking it for an actual alignment with diagnosis too much to do?
Without any further info of your truck, do you have lift, larger tires, other steering/suspension mods, etc.??
Old Jan 3, 2012 | 04:35 PM
Is the axle bent?
Old Jan 3, 2012 | 06:08 PM
Sheriff420's Avatar
Sheriff420
Is the axle bent?
Or the steering knuckles.
Old Jan 3, 2012 | 07:01 PM
seabass202's Avatar
seabass202
Like ZMAN said, it is usually negative camber issues when the upper ball joint "ear" fatigues and leans in due to weight/abuse/mileage. positive camber is a new one but if it's wearing the outside edge and toe is within spec it must be. I wonder if the castor being radically out of spec the engineered scrub radius could effect camber? I think it would. I would get a free alignment check done by a reputable shop and go from there. post the printout.
Old Jan 3, 2012 | 09:52 PM
CSCustomCars
No guys, it's positive camber. I've done alignments before, I know what all the measurements mean and what they are.
Don't know if the axle is bent. if it is, it's not readily visible as from a rough measurement, it's straight. Rough meaning as flat a ground as I have, put a tape measure up to either end and they were close (would have to do this again, and will since I know you guys will ask what the exact number is) Would have to put it on a rack to find out.
whitenuckle, its not too much to put it on a rack, I can only do it on a saturday when there are no cars in the shop, and that's a rare thing. Also, yes bigger tires, No lift, or suspension mods. 315/75/16 tires. I'm going to take some pictures i think of my front end for you guys, and maybe you guys can tell me if kt's been lifted, but as far as I can see, it hasn't. Bought it the way it sits currently. So either something isn't right, or I'm a retard and don't know what I'm looking for. And I'll admit it if I am being an idiot.
not many shops around here will through a vehicle up on an alignment rack for a free check just to get nothing from it.
Ball joints numbers were checked and cross referenced as I had this thought they might have been wrong as well. They crossed as good numbers and they installed fine.
Old Jan 3, 2012 | 11:48 PM
mrfarrell's Avatar
mrfarrell
it would need some sort of leveling kit to clear those 315's unless there really stuffed in there...
Old Jan 4, 2012 | 01:58 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I don't think so given its a 2500+diesel. I thought the 2500 + diesel had more stock lift?
Have you checked the condition of your shocks?
Old Jan 4, 2012 | 07:52 AM
CSCustomCars
^^ what he said.
I'm gonna run home on lunch today and take some pictures of the front end.
