Dashlight/taillight shorts when brake applied
Old Jan 22, 2012 | 06:19 PM
Jrichards05's Avatar
Jrichards05
Default Dashlight/taillight shorts when brake applied
I had a remote car starter installed in my 2001 dodge ram a month ago and everything was working fine but recently I started having problems with my dashlight/taillights. If I start the truck with the key, they won't come on at all. If I start it with the starter, they work but shut off as soon as I touch the brake pedal.
Any ideas as to what is going on?
Also, this may or may not be related but around the same time as the problem started, I had a broken tail light & pig tail replaced but I checked all the wiring and everything works fine and I can't see any problems with it.
I have checked all the fuses and they are all fine as well.
I took it to a local shop and they charged me $112 for the 1st hour to have a look and couldn't find the problem, they said they needed more time & $$$$.
Old Jan 22, 2012 | 07:25 PM
jasonw's Avatar
jasonw
Site Moderator
What brand of remote start? Hopefully you got a good one, cheap does not equate to good with a remote start. They are not all created equal.
A shop install it or did a friend?
Talk to the shop that installed it, if a shop did the work. There is usually a warranty associated with these things. If a friend... have them remove it, see if the problem goes away. If it does, then it was installed incorrectly.
Oh, and find a different shop for diagnostics. Mine doesn't charge me unless they find the problem.
Old Jan 23, 2012 | 08:12 PM
Jrichards05
It's a compustar and it was supposed to be a really good quality starter. I had a friend install it and he's a mechanic but he's out of town right now, otherwise I would have gone to him directly. Thanks for the advice so far
