DTC's on 1995 Dodge 318
Old Jan 24, 2012 | 01:50 PM
DODGERAM318's Avatar
DODGERAM318
Default DTC's on 1995 Dodge 318
Hey everybody, i just checked my DTC's and it gave me two codes.
33- A/C Clutch Relay Circuit.
35- Radiator Fan Control Relay Circuit.
As iv mentioned in my other threads my truck has a bad hesitation under acceleration, it will shutter/jerk pretty severely but if i floor it, it clears up and runs okay, until i let off. My question is will having these DTC's make my truck run this way? These are all the parts iv replaced in trying to resolve this issue- spark plugs, spark plug wires, cap and rotor, ignition coil, throttle position sensor, positive crankcase ventilation valve, positive crankcase breather, air filter, oil and oil filter. Iv also ruled out my MAF sensor being the issue. Could this all be caused by a bad IAC valve? I'm stumped, Id really appreciate any suggestions/answers. Thanks Guys.
1995 Dodge Ram 1500 4X4 5.2l 5 speed.
DODGERAM318
Old Jan 24, 2012 | 04:27 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Those codes have nothing to do with the way the engine runs. (is it the original PCM?)
This is what you need to look at, https://dodgeforum.com/forum/2nd-gen...um-thread.html
On a side note, I for one am not going to go search for your "other threads". So I suggest you keep it all in the original thread.
Old Jan 24, 2012 | 04:38 PM
BackwoodsRam's Avatar
BackwoodsRam
yea a IAC aint expensive. id try a new one, or clean the throttle body at the very least
