mind blown, 2wd lift kits?
Old Apr 14, 2012 | 09:36 PM
  #81
Wombat Ranger's Avatar
Wombat Ranger
Amen to that!!
Old Apr 14, 2012 | 10:43 PM
  #82
Augiedoggy's Avatar
Augiedoggy
Actually, body lifts raise the CoG less than a suspension lift, as they only lift the body, and the heavier parts don't move up.
exactly.... plus they dont mess with suspension geometry which can cause things like death wobble and premature wear on things....
they both have advantages... I'm thankful for one that I had my body lift when working on things...so much better access... the distributor has three extra inches all around and the cps sensor would have been a bitch without it...
Old Apr 14, 2012 | 10:47 PM
  #83
Augiedoggy's Avatar
Augiedoggy
that is why i hate body lifts
why ?
Old Aug 10, 2012 | 05:29 PM
  #84
Freehaf972500's Avatar
Freehaf972500
Hey generaljr how bad is it to buy either 2" or 3" coil lifts and put em on my 97 2500 2wd???
And endisnear that white ram with the 4" lift, how big are those tires 33s? That's what i want my 2500 to look like maybe alittle more lift an inch or 2?
Old Aug 10, 2012 | 07:03 PM
  #85
Freehaf972500
Hey auggiedoggy I wanted to put a 3" body lift and then 2" or 3" lift coils in and then 3" block kit in the rear, how big tires you thjnk I could squeeze under there? Stock rims hopefully toyo mud terrains, the 2500 what gears does it have in the rearend stock? What should I replace them with and how bad is an LSD going to cost to convert it?
Old Aug 11, 2012 | 01:30 PM
  #86
generaljr's Avatar
generaljr
is not that hard to install them, just need to disconect the sway bar, spindles etc, to be able to move the lower control arm all the way down to push in the coils
Old Aug 18, 2012 | 08:11 PM
  #87
Cumminsnotstroker#1's Avatar
Cumminsnotstroker#1
Originally Posted by tatitup8
that's what i was thinking!
what size tires you have bud, and also not truck
