heater core and a worry
Old Jan 27, 2012 | 10:19 AM
king_moaoe's Avatar
king_moaoe
Default heater core and a worry
well im going to do a flush of my heater core today or tomorrow, but i have been reading form other posts that there is a danger of blowing it, or that corrosion when i remove the dirt will make it leak, is there anything i can do to make sure this does not happen? im going to use a garden hose with just about half pressure.
Old Jan 27, 2012 | 11:42 AM
sam_priem's Avatar
sam_priem
i did a cooling system flush on my truck after i did my top half gaskets. i had the garden hose at full power and i had no problems with the heater core leaking.
Old Jan 27, 2012 | 11:57 AM
UnregisteredUser's Avatar
UnregisteredUser
If busting the corrosion loose will make it leak, then it's a goner anyway.
Old Jan 27, 2012 | 03:00 PM
supra300zx's Avatar
supra300zx
I first flushed mine with a garden hose and had no problems, except that it didnt 'flush' any bad crud out. I've read on another thread of someone running CLR through it and letting it soak. I ended up just swapping mine out. The heater core replacement was only $50 and it was simple enough and took about 6 hours without removing the dash. There is a youtube video if you're interested (just cant post the link since im at work)
Good luck
Old Jan 28, 2012 | 10:14 PM
king_moaoe's Avatar
king_moaoe
well when you can, will you post the link? so many videos would like to know a good one
Old Jan 28, 2012 | 11:28 PM
supra300zx's Avatar
supra300zx
http://www.youtube.com/watch?v=IKpQGjsXA5M
I believe that is it, just cant confirm since im in the field for the next few weeks and youtube is blocked. Its not great, but decent enough you can walk yourself through it. he does miss a couple parts... I ended up knocking the transmission gear indicator (turns the gear orange in your gauge cluster) cable off the steering column and took me a while to figure it out. Keep an eye out for tolerances/cables as the dash is shimmy'd back/ The nice thing about the new heater cores is the inlet and outlet lines can rotate and this is primarily the reason you can do the job without removing the dash.
