power issues low idle
Old Feb 1, 2012 | 05:43 PM
ferd15's Avatar
ferd15
Default power issues low idle
i have a 2000 ram 1500 4x4 with the 360. it idles at like 650.. my neighbor who ahs the same thing just the 2500 says it should idle at 1100
anyway to change that?
still my 4wd dosent work and i fixed all the vacuum lines exept if their are any in the cab. possibly should i switch them at the cad?
Old Feb 1, 2012 | 05:47 PM
ferd15's Avatar
ferd15
cleaned it out with seafoam, and engine restore. also if i take the the brake intake off the master cylender.. my idle goes up to 1100 like it should be.. any ideas?
Old Feb 1, 2012 | 05:50 PM
gdstock's Avatar
gdstock
1100 rpm is too fast after it warms up. Your neighbor is misinformed.
As far as the 4wd issue, vacuum lines appear to be the most common failure. Check them at CAD. Also, sear for CAD threads and there should be some ino on how to check to see if CAD motor is working correctly - OR - go to FAQ/DIY section and download the FSM for your truck. Good details there for checking the CAD.
Old Feb 1, 2012 | 05:58 PM
ferd15's Avatar
ferd15
ok well thnx. i downloaded the parts guide and the manual for my truck.. ill check it out. thnx ill try swaping them too i guess after i do some research.
Old Feb 1, 2012 | 06:06 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yup, 650 is spot on. As far as the 4wd and CAD go. Read this and perform the diagnostics. http://www.dodgeram.org/tech/repair/..._engagment.htm
