Camshaft Selection Help!!!
Old Feb 3, 2012 | 07:14 PM
djeven's Avatar
djeven
Default Camshaft Selection Help!!!
Got my engine halfway torn apart doing timing, water pump, airgap, new valve covers, etc and was thinking I should throw a cam in there while I am at it. So I got the 5.9 with supercharger, airgap intake, bigger throttle body, ignition, exhaust, tuner, bigger injectors. So any idea on what camshaft I should be putting in there? I have no idea what I am doing when it comes to selecting that sort of thing. I am looking for of course more power and torque but reading all those specs and lift duration or whatever just confuses me. So I use it for daily driving and occasionally towing stuff. An aggressive sounding one would also be nice to. Any advice is helpful as I would like to get one ordered so I can throw this beast back together and drive it again.
Old Feb 3, 2012 | 08:06 PM
An aggressive cam does not combine well with forced induction. In fact, its a REALLY bad idea...... Your best bet would be to have a chat with Comp Cams, or Crane Cams, let 'em know what ya got, what you want for an end result, and THEY will suggest a cam. That's their job. I would like to think they are good at it. (they have been doing it for a while after all....) They are also going to need to know just how much boost you plan on running, and what static compression ratio is for your engine.
Old Feb 3, 2012 | 08:31 PM
merc225hp's Avatar
merc225hp
^^ +1 Some good advice that then there is.
Old Feb 4, 2012 | 08:52 AM
Twisted Metal's Avatar
Twisted Metal
A Call to the fellas at Hughes Engines might not hurt either. Or contactthem through their website. www.hughesengines.com
