truck throwing code wats it mean
Old Feb 5, 2012 | 01:47 PM
mj23polaris's Avatar
mj23polaris
Default truck throwing code wats it mean
P1762 Gov Press Sens Offset Volts Too Low or Hi
Old Feb 5, 2012 | 02:02 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It means you need to replace the Gov solenoid and Gov pressure switch while your in there. It also means, when posting on a forum, keep related questions in the same damn thread, so we are all not guessing about the previous history/symptoms/diagnostics/problems.
Old Feb 5, 2012 | 02:14 PM
zman17's Avatar
zman17
No big deal bud, just trying to keep things organized, as my memory is not what it used to be.
mj23polaris
Lol ok man srry
Old Feb 5, 2012 | 02:17 PM
zman17's Avatar
zman17
Of course my Psychic powers seem to be working ok, since I can reply before you even ask/reply .
Old Feb 5, 2012 | 08:26 PM
mj23polaris
well ill get this from patc on Thursday when i get paid, hopefully it fixes the slipping when i nail it some times doin 55 and when i got it nailed and it shifts to 2nd
http://www.transmissioncenter.org/51...Up_Diagram.htm
prob get a deep pan and temp gauge to wile im at it
Old Feb 6, 2012 | 10:21 AM
Don't do the GM conversion, for less money, you can get the borg warner heavy duty solenoid, and it mounts right in. No mods necessary. Do a search, lots of folks sell 'em.
Old Feb 6, 2012 | 05:38 PM
zman17's Avatar
zman17
+1... Screw that GM conversion.
Old Feb 7, 2012 | 11:13 AM
mj23polaris
Found both the senor and solenoid for 65$ a piece, ill order when I get home from work
Old Feb 7, 2012 | 12:25 PM
Augiedoggy's Avatar
Augiedoggy
I bought my borgwarner unit and sensor both shipped for just over $100.00..(ebay).. there is a DIY on how to clean them with carb cleaner...there is a small screen that plugs and usually causes them to fail...I had it happen twice but the second time it was from pieces of the t converter that was going bad... if you filings arent magnetic its a good early warning to have the tranny served before it will need bigger $$ work as the converter may be shot.
