hub assembly
Old Feb 7, 2012 | 10:47 AM
Chris360's Avatar
Chris360
Default hub assembly
ok, I relaced my pass side bearing assemby and axel joint. I drove the truck under 3 miles and BANG just as i pull out of the walmart parking spot. The brand new assembly broke. thats what i get to do today! but what would coul cause it? just a faulty part? alignment issue? my guess is a faulty part.
Old Feb 7, 2012 | 11:08 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
wrong part or improper installation are some other causes readily available.
Old Feb 7, 2012 | 11:15 AM
Chris360's Avatar
Chris360
could you be more defenitive on improper installation? I removed the old one, cleand up the end of the housing (rust, grime, ect( with a wire brush, installed the new. torqued to 125 ft pnds. torqued axel nut to 175. i also installed the guard and shim that was there prevouse. If i did it wrong i dont want to make the same mistake twice.
Old Feb 7, 2012 | 11:31 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
When you inserted the axle shaft back in, where you careful about not taking out the seal within the axle/diff housing? Did you ensure that you got the axle shaft splines to mesh with the diff?
I'd like to presume you did given that you say you torqued everything down, but that assumes everything seated properly...or could have seated improperly.
Did you test spin the hub after torquing?
This also presumes the ujoint was installed properly.
This all presumes you have to correct parts too. I'm not meaning to knock you at all, just inquiring on the things that are not in your post. Indeed a bad part could plausible, but I tend to look at things as my own damn fault before getting that far.
Link to the parts you used?
Old Feb 7, 2012 | 05:16 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1... What brand hub assembly did you install?
Old Feb 7, 2012 | 06:49 PM
Chris360's Avatar
Chris360
Master pro i beleive..
well. It was my bad. I noticed some wear on the Axel threads but it did tighten. (guessing it was its last leg) So when I tore it down today the nut was loose with a broken carter key. So now I am waiting for my new Axel shaft.. heres a pic.
Old Feb 7, 2012 | 08:32 PM
dhvaughan's Avatar
dhvaughan
the nut was loose how ?
as in the threads had peeled off and the nut slipped off?
or had the nut simply backed off, but still had thread engagement?
Old Feb 7, 2012 | 08:35 PM
Chris360's Avatar
Chris360
peeled back... ever hear the expression, "tighten it just before it breaks"
thats the only thing i can figure. had just enough to get it where it needed to be until it was driven
Old Feb 8, 2012 | 06:37 PM
zman17's Avatar
zman17
You do know that the nut is suppose to be torqued to 175ft lbs correct?
Old Feb 9, 2012 | 10:35 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
At the time of that post.
