Cylinder #8 lean
Old Feb 15, 2012 | 11:35 PM
slimbeardy's Avatar
slimbeardy
Yeah, need to check plenum, and cat.... Federal, or California emissions?
Just replaced plenum gasket about 2 months ago or so. Federal emissions.
Old Feb 15, 2012 | 11:41 PM
gdstock's Avatar
gdstock
Originally Posted by slimbeardy
One person suggested cats, but Im having trouble seeing that as its not an entire bank issue, just the one hole.
........ hoping this isn't a common known issue or something stupid.
A word of advice - take it or don't - it's your choice.
One person told you cat, but you discount it. Three or four others have mentioned plenum AND possible cat on this thread, and you discount that.
To make it official, this is a common issue.
FWIW - take it or don't - it's your choice.
Old Feb 16, 2012 | 08:43 AM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by CPTAFW163
CHECK THIS:
If you have a 1994-1997 you have EV1 injector connectors. The square ones with the very thin tiny metal clip around the plastic connector. If that thin clip is missing, then you will get a miss on that injector. It will not be a consistent miss either. It could be completely NOT firing or sporadic.
Check to see that all your connectors have clips. If you have a 1998-2001 then you have EV6 connectors with the red lick tabs and you should not have to worry. Howver, it could be the injector connectors. they get loose and they won't bite on the male prongs in the injectors.
fyi we have been quoting EV1 as the connector style when in fact its a jetronic connector and the 2nd generation style injectors are called EV1...EV6 is the third generation. I read its a common mistake... but it makes things less confusing when I go back and reread injector threads...
I also have a lean cylinder (#1) with mis codes and poping under load. I replaced the injectors and will be test driving today.... I suggest you buy the $25 leak down tester at harbor freight and do that test if you havent already to check the heads condition...
Old Feb 16, 2012 | 12:11 PM
UnregisteredUser's Avatar
UnregisteredUser
It doesn't have to be lean to be hot. Pop a test pipe in place of the cat for a while and see what happens. Keep an eye on the codes to make sure the CEL is nothing more than cat failure during the test.
Old Feb 17, 2012 | 02:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The cat is clogged and the precat o2 is bad. And depending on how long the cat has been clogged, you may have burnt or badly carboned valves and or a cracked head. Unscrew the the o2 and see if it runs any better. Might be too late anyway. Verify the cat and do a compression test.
Old Feb 20, 2012 | 11:50 PM
slimbeardy's Avatar
slimbeardy
Problem solved - Sold the truck
Old Feb 21, 2012 | 01:51 AM
dlyter09's Avatar
dlyter09
I guess that's one way to fix a problem.......
Old Feb 21, 2012 | 05:57 AM
stewie01's Avatar
stewie01
Pretty soon they're will be post's from the new owner with "running lean" issues.
Old Feb 21, 2012 | 11:39 AM
UnregisteredUser
If at first you don't succeed, tell the new buyer "it's been good to me".
