No speedometer or OD light
Old Feb 11, 2012 | 06:29 PM
ChristheRED's Avatar
ChristheRED
Default No speedometer or OD light
99 Ram 4x4 1500 5.2L
While driving on I-40 in Oklahoma City (possibly the worst stretch of highway in the US) my speedo went belly up along with my OD light. The brake and ABS light illuminated. Everything still works normally except those items.
I've checked all the fuses, replaced the VSS and searched for the mystery "out of place wire" with no luck.
Any ideas?
Old Feb 11, 2012 | 06:31 PM
gdstock's Avatar
gdstock
Which speed sensor did you replace? Tranny or differential? Automatic trans?
Old Feb 11, 2012 | 06:39 PM
ChristheRED
The sensor is on the transmission extension.
Old Feb 11, 2012 | 07:13 PM
ChristheRED
Okay, total spaced out about one on the rear diff.
Also would that cause the ABS & Brake light to come on as well as the OD light to not work?
Old Feb 11, 2012 | 07:42 PM
dhvaughan's Avatar
dhvaughan
ABS and BRAKE being on are often associated with a bad rear ABS sensor in the top of the rear pumpkin. in the parts lookup its called rear ABS sensor, not speed sensor although it actually is the speedometer speed sensor.
Old Feb 11, 2012 | 07:47 PM
ChristheRED
Thanks for the support, I've ordered the part. In my book it is called RWAL brake sensor to add to the confusion.
Old Feb 11, 2012 | 08:15 PM
Ramzy's Avatar
Ramzy
In the Mopar parts manual it's also known as the tone ring sensor...lol so many names..
Old Feb 11, 2012 | 09:46 PM
gdstock's Avatar
gdstock
So many names, but the one you ordered is the right. My Ram had same problem when I got it but it was damaged wiring to that sensor.
Old Feb 11, 2012 | 10:39 PM
ChristheRED
I am still amazed that the interstate in OKC was so bad. I drive my beast all over the southwest on some of the nastiest roads and mountains imaginable and it took OKC's pothole alley to finally break it.
