I drove to work and the heater and gauge worked fine. 8 hours later on the drive home i noticed the temp gauge wasn't moving. And there was no hot air. The temp gauge just sits right on the very first mark which i believe is 130.
Is this a stuck open T stat? or something else?
I'm thinking your correct with the stuck T-stat. It wouldn't allow your engine to warm up, and of course no warm engine, no warm coolant, no warm heater core, no heat...
Should be an easy fix for you though.
