Will these lift springs work on a 2WD
Old Feb 17, 2012 | 09:25 AM
tssiTanker's Avatar
tssiTanker
Default Will these lift springs work on a 2WD
http://www.summitracing.com/parts/SLF-143/Application/?query=Year|1998|Make|DODGE|Model|RAM+1500|Engine+ Size|5.2L%2f318|Submodel|ST
It says application 4WD, but was just wondering if they would work the same on a 2WD.
Reason I'm asking is because I can't seem to find 2.5 lift springs and control arms for a 2WD anywhere.
Old Feb 17, 2012 | 09:54 AM
Don't think they will work.
Also, shouldn't need control arms for 2.5 inch lift. Could go with coil spacers?
Old Feb 17, 2012 | 11:30 AM
redheadhunter21's Avatar
redheadhunter21
NO they will not work.
Summit sells daystar spacers for 2wd trucks though
Old Feb 17, 2012 | 01:15 PM
tssiTanker's Avatar
tssiTanker
I have spacers on there now, but since they won't work I'll ask.
If I found lift spring for a 2WD would they give me a smoother ride, than with the coil spacers? Thanks
Old Feb 17, 2012 | 01:28 PM
Depends on the spring. Some will, some won't. I think it would be more a function of your shocks...... (spring rate plays a role here as well, along with spring design.... linear, or progressive rate, etc.)
Old Feb 18, 2012 | 01:05 PM
tssiTanker's Avatar
tssiTanker
Okay Thanks, will probably stick with the spacers and get new shocks. As the shocks are still the original ones from the factory. Probably doesn't help with the ride at all. lol
