Woohoo p0455 gone
Old Feb 27, 2012 | 09:14 AM
A_POLVADO's Avatar
A_POLVADO
Default Woohoo p0455 gone
Smoked the evap system this weekend the plastic hose were the rubber line connects to it split the rubber hose in half.Replaced 80 miles no code yet. BUT SET A P0304 on the way to work cyl 4 misfire I know what that is cracked head have a new set ready to install. i have 50 lbs of pressure cyl 2 and 4
I have been chasing the 455 code since i bought this truck 3 yrs ago
Old Feb 27, 2012 | 12:39 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Thanks for letting us know and congrats on finally get it figured out.
Old Apr 22, 2012 | 02:48 PM
Pstiles's Avatar
Pstiles
How much did the smoke test run you? Still trying to track down my P0455. So far I have replaced the gas cap, and purge solenoid valve. I have visually checked lines, and hoses that connect to vapor canister. Everything seems to be intact.
Old Apr 22, 2012 | 02:54 PM
zman17's Avatar
zman17
Did you bother to do a search here on DF and try this? https://dodgeforum.com/forum/2nd-gen...-leak-fix.html
