Truck almost stalls
Old Feb 28, 2012 | 03:37 PM
ttab's Avatar
ttab
Default Truck almost stalls
bought 2001 dodge ram 1500, 130k km about a month ago, since It has randomly began to idle low and start seeming like its about to stall. It has actually cut about on 3 different occasions, other times it drives perfect. Also today i drove and parked for a when my truck started to idle low and seem to stall when the CHECK GAUGES light came on and oil pressure went to 0, turned key off and back on and it went back up. Hoping some one may have an idea of what the problem may be
Any ideas?
thanks
Old Feb 28, 2012 | 04:05 PM
Yank the throttle body, and clean the snot out of it. (new TB gasket is only two bucks.) ESPECIALLY the IAC well on the back. (pull the IAC motor out, but just wipe off the pintle, don't move it, or do anything else to it.....) Reset the pcm. (just leave the battery unhooked while you are doing your cleaning.) Make sure all connectors are clean when you put it back together.
Check gauges lite, and all that, may have been just because it was idling low.
Old Feb 29, 2012 | 12:16 PM
knoxy's Avatar
knoxy
I had same symptoms with a code about running rich. Drove fine except at low/idle RPM.
Put in new O2 sensors and problem went away.
Old Feb 29, 2012 | 12:31 PM
charlie1935's Avatar
charlie1935
Mine did that a few weeks after replacing the IAC.
New battery fixed it.
Old Feb 29, 2012 | 12:35 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the codes also, https://dodgeforum.com/forum/2nd-gen...code-list.html
